Aug 18th, 2024, 7:18am
Theory of Mixer Operation (Read 2037 times)
aaron_do
May 10th, 2006, 12:15am
anybody know of any good simple explanations of Mixer Operation. I've read a couple of papers which gave some pretty good explanations but most people simply stick to saying its a simple multiplier. Just to give you an idea of what i'm talking about,
                           Rvariable
node X_________vvvvvvv_________output node
l            l                                       l
l            l             ------>                 l
l            >              I1                     l
(I)          > Ro                                =  Clarge
l            >                                      l
l            l                                        l
gnd      gnd                                  gnd
lets represent the mixer as a variable resistor and the output has a large capacitor connected to limit the LO-IF leakage. The input is comes from the LNA and is equal to gm.Vin, here just called I, and an output resistance r0. The way I see it, we can represent Rvariable as,
Rvariable=RDC+RLOsin(wLOt)
in other words, it has an average component and a varying component which depends on the LO swing (RLO<=RDC). So the explanation I can think of which seems to correlate well with simulation goes like this,
VX (RF) = gm.Vin (RDC//R0)                       // means in parallel
I1=gm.Vin.(RDC//R0)/RDC
Vout (IF) = gm.Vin.RLOsin(wLOt).(RDC//R0)/RDC
so from the final equation, we need to maximize RLO (the LO swing) and RDC to optimize the gain. The maximum gain is 1 because RLO<=RDC. This seems to correlate with simulation, but a better explanation would be welcome.
note as i understand it, RLO/RDC can actually be as high as 4/pi from the fourier expansion of a square wave or something like that...can't really remember.
thanks,
Aaron
mikki33
Analog/Mixed
Signal/High Speed
Israel
Re: Theory of Mixer Operation
Reply #1 - May 17th, 2006, 6:07am
See the classic:
Ho-Jun Song and Choong-Ki Kim, ’An MOS Four-Quadrant Analog Multiplier Using Simple Two-Input Squaring Circuits with Source Followers’, IEEE Journal of Solid-State     Circuits, Vol 25, No 3, pp 841-848, June 1990.
(I didn't find it in the Internet, you can use the library). This worked 10G with 0.13 process.
Another good one is
http://citeseer.ist.psu.edu/cache/papers/cs/12470/http:zSzzSzwww-scf.usc.eduzSz~...
If you don't have time to do it good
you will find time to do it again
