MokoKoya
Hello everybody,
I have created a verilogAMS testbench which contains many 'ifdef compiler directives. I want to be able to set which directive I want, run the simulation and then once complete reset the simulation with a diferent directive and start the simulation again.
I would like to do this automatically until I have simulated using all the different compiler directives, and run every test.
I am unsure on how to do this, and is using the PLI the correct way to achieve it?
I have never used PLI before and would apretiate any advice on the topic.
Thank you for taking the time of reading my query, Andrew
