Jul 16th, 2024, 11:36am
PLI (Read 2138 times)
MokoKoya
PLI
May 10th, 2006, 2:25am
Hello everybody,
I have created a verilogAMS testbench which contains many 'ifdef compiler directives. I want to be able to set which directive I want, run the simulation and then once complete reset the simulation with a diferent directive and start the simulation again.
I would like to do this automatically until I have simulated using all the different compiler directives, and run every test.
I am unsure on how to do this, and is using the PLI the correct way to achieve it?
I have never used PLI before and would apretiate any advice on the topic.
Thank you for taking the time of reading my query,
Andrew
Re: PLI
Reply #1 - May 15th, 2006, 7:08am
Isn't this a matter of running ncvlog -define with the appropriate argument, elaborating, and simulating (or using ncverilog +define for the equivalent one-step flow solution) - and doing this for each compiler directive?
I don't think PLI would help - because you'd need to recompile - these are compiler directives, and so you need to alter what the compiler sees.
