Aug 16th, 2024, 11:30am
question in simulating amp (Read 4682 times)
glacieryy
May 11th, 2006, 10:56am
I have a problem on how to simulate the frequency  respoonse  of amp in a SC integrator?
When doing this simulation,should I include the CMFB block?The CMFB block is implemented by SC curcuit.
Thanks in advance.
glacier
Re: question in simulating amp
Reply #1 - May 12th, 2006, 7:02pm
Glacier,
  It would be best to include the CMFB network in the simulation.
To include the CMFB network, you might try two approaches:
1) Use Spectre's analysis dependent switches to force the dc
   operating point with common-mode feedback active and
   the ac analysis with the common-mode feedback disabled.
2) Use SpectreRF's sampled pac analysis. Sample the frequency
   response when the amplifier is in the normal mode of
   operation.
glacieryy
Reply #2 - May 12th, 2006, 9:12pm
Hi Sheldon,
Thanks for your reply.
But may I ask a simple question?I am afraid that I do not understand the first way you have  told me.Could you give me something in detail?
Thanks a lot.
Best wishes.
Glacier
Reply #3 - May 15th, 2006, 7:12pm
Glaicer,
I am not familiar SpectreRF. But I have a simple method. Make a CMFB macro model using R, C, and controlled voltage source, although it is not very accurate.
.SUBCKT CMFB_G7 P1 P1D P1DB P2 P2D P2DB CBIAS CMC CMO VDD VON VOP VSS
R1 CMC CMO1  200E3
R0 CMO2 CMC  200E3
V1 CMO 0  1.65
E1 CMO1 0 VOL='V(cbias)-(V(cmo)-V(VOP))' max=3.3 min=0
E2 CMO2 0 VOL='V(cbias)-(V(cmo)-V(VON))' max=3.3 min=0
C2 VON CMC  125E-15
C0 VOP CMC  125E-15
* END OF SUBCIRCUIT DEFINITION.
.ENDS CMFB_G7
where VOP and VON are the differential output of an opamp, CMO is the bias for common mode voltage, CBIAS is the system bias for tail current, CMC is tied to the tail transistor in the opamp.
Best regards,
Yawei
