Jul 20th, 2024, 3:10am
chopper stabilization amplifier question (Read 2327 times)
chungmnig
May 16th, 2006, 3:34pm
Hi~~
i designed a chopper amplifier
the differential output signal like attached file.
why the spike is so large?
can anybody now why ,is it normal?
i often see the output signal will into a low pass filter.
is when go into the low pass filter the spikes will disappear.
thanks a lot
Jerome
Toulouse, France
Re: chopper stabilization amplifier question
Reply #1 - Jul 4th, 2006, 2:03am
Hello Chungmnig,
You are right: the low pass filter is meant to remove spikes.
One thing you should aware of: even if spikes are removed,
they contribute to the offset. The offset is strictly proportional
to the frequency (that is why high precision chopper use low
chopping frequency).
I got a chopper back from the fab last year. It is paced at
2MHz (a bit like yours). I have measured an offset 150uV
due to charge injection. This offset was strictly proportional
to the chopping frequency (<100uV at 1MHz).
If I were you, you would try to decrease the amplitude and
the duration of the spike.
Good luck, Jerome.
RobG
Bozeman, MT
Reply #2 - Jul 5th, 2006, 12:39pm
I'd be a bit worried because the size of the spikes seem to be signal dependent.
