lunren
Asia
Thanks. Now I can run the pss and pnoise simulation in my work, but I still confused by several questions: 1) Does pnoise simulation don't need such parameters as flicker noise parameters:KF or AF? If the model doesn't have such parameters, how can the simulation result be reliable? 2) How can we set the frequency sweep range rationally? For example, If my VCO oscillation frequency is 500MHz, and my PLL output frequency is 125MHz(divided by 4). 3) After we get the phase noise result, how can we get jitter characteristcs? 4) What's the exact meaning of BEAT FREQUENCY? If my PLL input is 50MHz, the VCO freqency is 500MHz, How can I set the beat frequency? 500MHz or 50MHz?
