Sep 26th, 2026, 7:30pm
Pages: 1 2
LDO Stability check ... (Read 10309 times)
always@smart
ASIA
May 18th, 2006, 6:31pm
Dear All,
This is my FIRST post in this forum, hope someone can help me out ...
I recently design an LDO and it is used to drive some cascaded large inverter. What should I put as the load for the ac analysis?
I have read some papers, they just put a RL (which equivalent to the sinking current at the load). I did so to put RL (and a current source) for 0A to 8mA, and i got good PM at all corner. Which is better, a current source or RL?
However when I plug the Inverters as a load, the LG and PM vary alot at all corner. For example the LG may drop 10db or may go upto 70dB. The PM may drop to negative or some case it may goes beyond 180 degree (which is weird).
I found out that the impedance of the inverter (i unpluged it from LDO, give VDD , ac=1), vary from few hundred ohms to few hundred mohms, this might cause the LG (gain of the PMOS) vary. The reason behind this is because the inverters is fed from a Limiting Amplifier which Output Commod Mode is 1.2V, and it may vary across all corner, this cause the DC point of the inverters change and eventually , at different corner, MOS of the inverter operate at different region.
For the transient analysis, what kind of setup should I do for my circuit? Should i give a step response at the VDD_Supply Voltage step 0-3.3v  (with inverters) or current step 0-8mA (without inverters) at the VDD ?
Thanks in advance
Smart
Smart
Raul
San Jose, CA.
Re: LDO Stability check ...
Reply #1 - May 18th, 2006, 10:26pm
Without seeing the architecture you are using, it is somewhat hard for me to imagine why you are seeing some of the things you describe. You mention PMOS, so i assume you are using Miller compensation in which case no load & low ESR should be your worst case stability condition. It would be helpful if you post what test condition causes what PM or LG change, etc...
A fool proof way of checking stability is the transient load step test. Check how much is your maximum load current and use a pwl current source with a 1 ns rise and fall time and let it run long enough for the output voltage to settle after the overshoots subside. By looking at how much ringing you have you should get a good idea of how stable your loop is. Make sure you set your transient analysis tolerance to conservative.
AC simulations should correlate if you break the loop correctly and mimic all the necessary capacitances at the break point. If AC doens't match transient i'd believe transient analysis.
regards, Raul Perez
always@smart
ASIA
Reply #2 - May 19th, 2006, 1:24am
Dear Raul,
Sorry, I should have given the diagram earlier. Please refer to the attachment...
You would notice that the 1st stage inverters input is fed from Limiting Amplifier (LA), which has common mode around 1.15 ~ 1.25 accross all corner. The LA supply is from different voltage regulator. The inverter supply from LDO, this LDO does not have external capacitor, internally there is a 100pF cap, and the error amplifier is a 2 stage OTA. The maximum switching current flow through VDD24 is 8mA.
I have done 3 type of stability check for the LDO:
      1.  I unplug the inverters, and putting a estimated CL ( for the inverters capacitance) and RL= 300 ~ 2.4M ohms (equavalent to current sink from 1uA-8mA) at the output of the LDO. I manage to get good PM (around 70 degree) with no much LG variation (around 60 to 70dB)at all corner(provided all MOS in saturation). No matter i break the loop at PMOS's gate or the resistor node, the result show almost the same.
      2. I unplug the inverters, and putting the CL and a current source (0-8mA) at output of the LOD. This setup also giving me good PM and no t much LG variation at all corner. I have a question here. comparing the setup 1 which using a RL and the setup 2 using current source, which give more accurate result. In this two setup i do not see it take the load impedance into account , or does it?
      3. I plug the inverters as the loading of the inverter, and the LA operate at Common Mode=1.2v. However this time the PM and LG vary lot, PM can vary from negative, and to more than 180 degree (kinda weird, right?). The LG can vary from 5dB to 70dB. Here I do some more analysis, I measure the inverters impedance (by giving a Vdc=2.4, ac=1), the impedance vary from 100 mille ohms to 400ohms, due to the DC point of the inverters from LA is changed across all corner and causing the inverter operate at different region. Should I trust this result?
I have done the transient analysis  (without inverter) as mention by raul, putting a ipwl and sweep current from 0-8mA within 1ns. The VDD24 show very stable , without any overshoot and ringing.
I have a question here, should I put the inverter back, and sweep the VDD33 and provide the Common Mode=1.2V to the LA input (similar to the 3rd setup in AC analysis)?
Any other inputs are all welcome
Thanks in advance
Smart
Smart
Raul
San Jose, CA.
Reply #3 - May 19th, 2006, 4:25pm
   Hi Smart,
      I would suggest a number of things:
1. Why do you need a 2-stage OTA? That leaves you with three gain stages counting the power PMOS, this is going to be difficult to compensate/stabilize and your open loop gain is pretty low for such a large amount of gain stages anyway. You could use a cascoded gain stage folded cascode and get as much gain as you get with the two-stage OTA. Then with Miller compensation you can easily split the poles of your two gain stage system. Since you don't have a load capacitor ESR either, you don't have a zero to try to help you compensating this system. Here you have no choice than to keep it simple to make your life easy.
   I think that your stability problems are probably due to the output node's impedance varying widely since the impedance of this node (when it is high) will give you a pole that will move towards lower frequency and it will be getting close to the other pole that is not being split by Miller comp in your 2-stage OTA.
regards, Raul Perez
always@smart
ASIA
Reply #4 - May 19th, 2006, 7:59pm
Raul wrote on May 19th, 2006, 4:25pm:
   Hi Smart,
Dear Raul,
Thanks for your input.
Firstly, I would try your suggestion by changing the 2-stage OTA to folded-coscode OPA.
However, I believe it might be able to solve the PM problem, but the LG problem in the setup 3 i mentioned in last post will still exist, since i notice that, If I plug the inverter for AC analysis,  the gain of the Power MOS can vary from -10dB to -40dB (depending on the inverter's Impedance )and cause the LG drop to 5dB to 50dB.
What would you say regarding this phenomenon?
2. For the AC analysis, putting current source or a RL, which is better setup?
3. What supposed to be appropriate LG for feedback factor is 1/2?
Will get back to you once i have done the new LDO with folded-cascoded OPA.
Smart
Smart
taofeng
Belgium
Reply #5 - May 21st, 2006, 4:36am
First, since the LDO you are using is for the application of digital power supply, I think the setup with RL is more accurate. From my point of view, with the ideal current source , it is so strong that make the setup of DC operation point easier.
Basiclly, I agree with the Raul that in order to make your life easy, it is better to use cascode or folded cascode structure instead of 2-stage OTA since you have to be very careful for the compensation of multistage amplifier.
For your circuit diagram, I will treat your 2-stage OTA just as an OTA block regardless of the detailed structure inside. Then, the diagram you shown is reduced to a two poles system. The output of OTA comtributes one pole, and the other is located in the output VREG2.4. Two-poles system is inherently not stable, this is why you add miller compensation capacitor to split the two poles. A left-hand plane zero is contributed by the compensation resistor and capacitor, this can help in keeping the phase margin.
For the tradiotional LDO design, large output capacitor is needed in order to stabilize the system, by which I mean that the dominant pole is situated at the output regardless of the load current. However, this is not the case in your circuit if not mistake. The 100p F is too small to make the output node dominant in all the range from 1uA to 8mA, this is not good for stability. What is more, the miller compensation cap is added to just make the output node of OTA more dominant. So, I assume that the dominant pole is at the output of OTA.
You mentioned that both setup 1 and setup 2 give very good PM. I think this is not surprise. since the dominant pole is situated in very low frequency(if you use the 2-stage OTA, then the output impedance of OTA would be very large, plus the big miller compensation capacitor, this pole is in very low frequency indeed). Hence, the consequence is to make these two poles well seperated and what's more, you have one left-hand plane zero to keep the phase. This is why you did not see any change from the frequency response when you tune the RL or IL in a large range.  If you reduce the value of miller compensation cap or increase the decoupling cap, you will see the difference.
For the setup 3 where you plug the inverters in, I am fine with the way you find the equivalent impedance. If not mistake, you swept the DC voltage of the input which comes from the LA(this equilatent to RL), and saw the frequency response. The weird thing you find is most probably due to that under certain condition, the LDO is out ot regulation , or in other word, the current vaule is beyond the current capability of the PMOS pass transistor. Suppose you have 100 milli ohm, then current being sink should be 2.4/(100*10-3)=24 Amp. This is huge !!! , indeed. Of cause, if you take 400 ohm, the sink current 2.4/400=6 mA, then this value is within the 8 mA specification of you LDO design.
However, the problem with this setup 3 is that during switching or in transient simulation, the impedance change of the inverter is rather difficult and more than the way you use in setup 3 since it is a switch(characteristic of digital circuits). Pluging the inverter to find the frequency response ,that is nothing help. This accounts for why you  did not find any problem during the transient simulation while there is weird things with setup 3 frequency simulation, by which I mean setup 3 could not represent the real situation.
what I suggest:
1.  RL and CL as load,
2.  make sure even in the worst case, you still have decent phase margin, just as Raul mentioned before. In your case, lowest current condition.
3.  The most important thing: do the transielant simulation with your real digital circuit. In your case, adding the cascaded inverters.
if these test all pass your sepcification, then it is ok anyhow.
Hope this can help !  I would really like to discuss with you guys on this.
taofeng
always@smart
ASIA
Reply #6 - May 21st, 2006, 9:59am
Dear taofeng and Raul,
Thank u very much for your reply.
First of all, I have already implemented the new LDO with single stage folded cascode OTA (Gain=60dB). The Load capasitor maintains same 100pf with additional CL (0.1pf to 10pf) for inverter, Pad and the Probe cap.I just use a 10pF compensate capacitor that connector btw the gate and drain of the Pass Transistor (PMOS) or maybe can you refer me a better compensation?
Setup 1. Ok, I agree with taofeng, which the current source setup might be mainly for DC point checking to ensure the PMOS is still maintaing in saturation with the MAX current sink. I have a question here, do i have to worry that with minimum current (1uA) sink the PMOS goes to weak-inverton region (Vgs slightly smaller than Vth)?
Setup 2. With the RL and CL, I managed to get good PM (at least 60) at all corner even at 1uA current sink.
Setup 3. This time although I plug the LDO with the Inverter, the PM show almost the same result as setup 2, apart from LG still has quite big variation.
I have some worry here, with only a CC compensation, I can see there is a zero introduce in btw dominant pole and the 2nd pole, can you explain this?
I will show you guys the bode plot if it is necessary .
regards,
Smart
Smart
taofeng
Belgium
Reply #7 - May 21st, 2006, 11:43am
For the simple 2-stage LDO design , I think the simple miller compensation is good enough.
You do not have to worry about the weak-inversion effect, since it is normal that your PMOS pass transistor experiences the saturation, linear and sub-threshold regions with so wide variation in the load current. However, the advantage of making the PMOS pass transistor always in saturation is that it could ensure a high output impedance of PMOS, which is good for the PSRR, especially in high frequency.
What do you mean the CC compensation ?  if you mean only CC compensation (without compensation resistor RC), then most probably the zero in between the dominant pole and second pole is caused by the parasitic pole in side the folded cascode OTA. However, if you mean CC compensation with the compensation resistor RC, then the zero is caused by the CC and RC, which is very apparent.
I do not know if I make it clear for you ?
Could you please attach some simulation results ?
best regards,
taofeng
always@smart
ASIA
Reply #8 - May 22nd, 2006, 3:46am
Dear taofeng and all,
Referring to the attachment.
As I have mentioned earlier, this LDO is designed with folded cascode, 100pF internal capacitor with a 10pF compensation capacitor accross gate and drain of pass transistor (without RC). The Bode Plot as noted with "A" is plot for RL=300ohms and "B" is RL =2.4Mohms. Both PM giving good result (>80 degree). Both "A" and "B" have a Zero introduce in between 2 dominant poles (although it's not clear in "B"). Bear in mind this running with setup 2 as I mentioned early.
Now when i do setup 3 (plug invertes for the load, CM of LA=1.2V) and I give a step response to VDD33, the result looks good at temp -40 and 27 (inverter current sink is about 1mA). However some kind of oscillation showing when temp =125 (inverter current sink is about 3mA). Can anyone explain this , how can I solve it?
Maybe it's the compensation problem, please advice me a better method if you have ...
Hope someone can help.
Thanks in advance
Smart
Smart
always@smart
ASIA
Reply #9 - May 22nd, 2006, 3:54am
Dear all,
Sorry i just have no idea how to attach 2 files in a post.
Here is the transient result.
regards,
Smart
Smart
taofeng
Belgium
Reply #10 - May 22nd, 2006, 6:48am
It is strange indeed.
If the folded-cascode OTA is designed approriately, by which I mean all the internal poles and zeros are (well) beyond the unit-gain frequency, then you only have two donimant poles left: one is at the output of OTA, and the other is at the VREG2.4.  Since you do not have RC , then there should be no left-hand plane zero to keep the phase margin. However, from your simulation plot, it seems there is a zero(maybe unintentional), so I think it is probably due to the internal node inside the OTA. Check the OTA circuit, or could you please plot the gain and phase @ the output of OTA ?
Second, you should really ask yourself that: which pole should be the dominant one ? I am wondering you have swappable dominant pole here when you change the load current. From my point of view, this is not recommended in terms of stability.  Suppose, when in 2.4M ohm condition, the pole at VREG2.4 is 1/(2*pi*2.4*1e6*100*1e-12)= 663 Hz. How is the output of the OTA, let's assume that the output impedance of OTA is 10M ohm and there is no miller effect(since the gain is approximate zero in this 1uA load condition), so 1/(2*pi*10*1e6*10*1e-12)=1592 Hz. these two poles are of cause not well seperated.
Finally, I am not fully understand the simulation setup for the step in the VDD3.3.  is this kind of Line regulation ? I don't think so.  How large the value and step of you stimulus ?
hope this helps !
regards,
Junfeng
taofeng
Belgium
Reply #11 - May 22nd, 2006, 6:54am
could you also please tell how and where you cut the loop ?
always@smart
ASIA
Reply #12 - May 22nd, 2006, 9:50am
Dear Jun Feng,
Thanks for your reply.
Let me answer your question that i can answer at this moment (I'm at home now=). )
You meant to check 1. open loop gain or 2. the loop gain, since i have already broken node between output of the OTA and the gate of the pass transistor to get the LG and PM, please clarify this so i will show you the result if you meant the 1st case.
Ok, I suppect this situation happen in the circuit too. Before i am putting the Compesation Capacitor=10pF(without RC), the two dominant pole  are about 10~100 decade seperated away. I will get back to you regarding the exact result before and after compensation which node playing more dominant. Any other details you need?
In fact there are 2 possible input point (after the LDO is connected with the inverters) for checking the step response in my circuit 1st. the VDD3.3  and 2nd. the input of the LA (which is differential signal).  I have chosen VDD33 for step response (0v at 0s and 3.3v at 10ns ) to simulate when the LDO is poweredp and the LA i have given it's Common mode which is 1.2v (this might not be correct one).The result was shown in my last post. You are welcome to comment this setup. =)
Simply cut between OTA's output and the Pass transistor's gate. I am using C@dence Spectre, so at the broken points, I inserted a "Iprobe" (it will take care of the DC poin just like Middlebrook), and run the stability analysis in Spectre. I have also tried breaking node btw resistive feedback and Vp of the OTA, it shows almost same result.
Anyway, I will get back to you later. In the meanwhile, If you have any further comment please advice me...
Thanks in advance.
Smart
Smart
taofeng
Belgium
Reply #13 - May 22nd, 2006, 11:13am
Of cause, I mean open loop gain. In detail, I want to know the open loop gain/phase of the OTA (the first stage) and the open loop gain/phase @ VREG2.4 (which is the total gain of the 2-stage ), you can plot in the same graph.
Basically, I agree with you that no matter where you cut the loop, the simulation results would be almost the same. However, the traditional way is to break at the node beween resistive feedback and Vp of the OTA. By doing this, you can check the gain/phase of the first stage(OTA).
From your simulation above, I see that the overal gain is around 60dB if not mistake. However, you mentioned before also that the OTA itself gives 60dB, which means that your Pass transistor does not have any gain or the gain is so very low ? it is weird actually.
I would suggest the following things:
1.  pick-up the folded-cascode OTA only, and do the pole -zero(stability) analysis, by which I mean the open loop analysis.
2.  sweep the RL in a decent range, let's say 1k to 100k, and plot the gain/phase.
3.  increase the ramping up time from 10ns to let's say, 1us, just to see if there is any difference. Because 10ns is too fast to activate the loop(10ns means 100MHz bandwidth, it is impossible for your case with the miller compensation. From your simulation above, the bandwidth is from 2MHz to 25MHz, so take 1us as an example ).
hope this helps !
best regards,
Junfeng
uncle_ezra
Reply #14 - May 23rd, 2006, 3:25am
I have designed a similar circuit and from the diagram your circuit have 2 dominant poles. The compensation you are using won't help at all. How large is the pass transistor?
I would compensate either by adding ESR (if permitted) in the output so a zero is created or use NMOS or native NMOS (if available) as your pass transistor.
Pages: 1 2
