Michiel wrote on May 31st, 2006, 10:21am:It is the minimum size I can enter in Virtuoso. I changed the values directly in the netlist, triggering some fatal errors during hierarchy flattening.
OK, perhaps the model card is set up to convert to um.
Quote:Geoffrey_Coram wrote on May 31st, 2006, 9:39am:Also, from the path you showed, models/LP_50A/mm11: does this use Mos Model 11 from Philips?
As far as I know it does.
Can you figure out which MOS11 it uses? The possibilities are mos1100, mos1100e, mos1101e, mos1101et, mos1102e, mos1102, ... mos11021t.
I just set up a test case with mos11011
model nsvt mos11011
which then uses the default parameters for the model, and I didn't see any problems.
If you can copy the model file to your local directory, you might try deleting half of the parameters and then seeing if it still errors out. Or deleting the noise parameters (ponfa, plnfa, ...) and seeing if that is the issue.
