Aug 15th, 2024, 10:32pm
saving mulitple operating points in spectre tran (Read 2263 times)
kmoore
dublin
May 23rd, 2006, 3:14am
Spectre question:
I would like to save a number of operating point state files from in a very time consuming transient simulation I'm running so that I can then run ac analysis using the "prevopoint=yes" option for AC analysis at each timepoint.
As I undertand it, the ac analysis will use the spectre.fc file created at the end of a transient sim when "prevopoint=yes".
So how can I create spectre.fc  files at specific time points  during the one transient sim?
I see in the transient options form that there is a parameter "infotimes" which can be used to save the full dc operating point as a binary at specific time points.  But as far as I can see  the ac analysis needs a textfile in the same format as the spectre.fc.
Any ideas on this?
thanks,
Kevin.
Re: saving mulitple operating points in spectre tr
Reply #1 - May 30th, 2006, 5:06am
Kevin,
  Have you tried the acnames and actimes option for transient
analysis? Of course you need to be using a recent version of
Spectre.
