Aug 18th, 2024, 5:22am
resolution of ADC? (Read 2736 times)
chungmnig
resolution of ADC?
May 28th, 2006, 8:10am
Hi~~
If said a ADC has 12bits,then the reference voltage = 2V
then the smallest can measured voltage = 2/(2^12) = 4.88mV (it means LSB) ,
and  if reference voltage = 1 V --> 1/(2^12) = 2.44mV ,
so the reference voltage =1 can measure smaller voltage if ADC's  bit =12
Is this statement is right?
thanks~~~
Croaker
Re: resolution of ADC?
Reply #1 - May 28th, 2006, 9:21am
Yes.  If you have a 4-bit converter and full-scale voltage is 10 V, the value of the LSB is 10/(2^4)=0.625 V.  The highest value is 15, which translates to 9.375 V, or Fullscale - 1 LSB.
I hope this eases your mind!  :)
Cheers,
Marc
Paul
Switzerland
Reply #2 - May 28th, 2006, 3:52pm
yes, your statement is correct if your ADC is quantization noise limited. In many cases, the resolution may however be determined by the thermal noise level, in which case the lowest value to be measured is reference-independent. In that case, using the larger reference voltage maximizes your dynamic range (if we neglect distortion).
Paul
