Paul
yes, your statement is correct if your ADC is quantization noise limited. In many cases, the resolution may however be determined by the thermal noise level, in which case the lowest value to be measured is reference-independent. In that case, using the larger reference voltage maximizes your dynamic range (if we neglect distortion).
Paul
