Aug 18th, 2024, 10:21pm
Number of Monte-Carlo runs (Read 146 times)
Visjnoe
May 30th, 2006, 5:49am
I had a discussion with someone and since statistics is not my cup of tea, I'm posing the following question:
1) Is there any formula that relates the number of Monte-Carlo runs to the confidence level (e.g. 6σ)?
2) Can that number depend on the type of circuit? For example, in a flash ADC one could consider each preamp/comp out of 2^N
   to be already an independent, statistical sample.
Kind Regards
Peter
ACWWong
Oxford, UK
Re: Number of Monte-Carlo runs
Reply #1 - May 30th, 2006, 5:59am
Statistics aren't my cup of tea either (although like most, I took a few sips from the stats cup many moons ago at university)
but i was once told (on good authority i was assured) that:
"The worst case of 10 MC runs gives an indication of 2sigma for a gaussian distribution"
Often I use it and find its quite good (and definately speeds up my design work). My head tends to hurt if I start to think too much about the maths... maybe someone with a clear head can educate us with a proof/disproof ??
raf
Reply #2 - Jun 27th, 2006, 5:43am
Hmmm if you mean +/- 2 sigma around the mean then 10 MC runs seems too small. If you mean +/- 1 sigma around the mean, well is that really good enough anyways?
I don't know the answer either. I use brute force approach. I keep running MC sims until my answer doesn't change anymore. Then this is back annotated into simulink sims to run system level MC.
-Raf
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #3 - Jun 27th, 2006, 7:46am
Very long time ago, I red an article proving that it is enough 95 runs to get Sigma with 5 % accuracy (after plotting hystogram, of course)...
If you don't have time to do it good
you will find time to do it again
