Jul 23rd, 2024, 10:23am
exclude transistor from noise analysis (Read 4871 times)
mkaragou
Germany Soest
Jun 01st, 2006, 4:42am
Do you know if there is a way to exclude transistors from the noise analysis in spectre?
Is there a option to make a transistor noisless like it is possible for resistors?
Because sometimes it is nice to see the noise contribution of every single transistor to check where the dominant noise source is located.
Furthermore is it possible to simulate only one sort of noise soure like only thermal or only flicker noise?
Again the goal would be, to see what kind of noise is dominant in the design.
Chromatik
Re: exclude transistor from noise analysis
Reply #1 - Jun 1st, 2006, 6:12am
Depends for the simulator you're using...
Anyway, if you change the transistor model to a noiseless model, the noise contribution of the transistor would be fine  ;)
mkaragou
Germany Soest
Reply #2 - Jun 1st, 2006, 6:21am
I am using spectre in cadence v5.0.33 my models are written in bsimv3.3
I already have set the noia, noib, noic parameters to zero to get rid of the flicker noise
but I have not found any way to switch off the thermal noise in the model files!
mkaragou
Germany Soest
Reply #3 - Jun 1st, 2006, 6:51am
http://www.designers-guide.org/Forum/?board=rfsim;action=display;num=1091334193
I should develop the good habit to use the search function before stating question!
mkaragou
Germany Soest
Reply #4 - Jun 1st, 2006, 7:38am
One thing that would be nice to have would be, the possibility to present results of the noise summary graphically when a parameter is sweeped.
Reply #5 - Jul 20th, 2006, 1:57pm
You can use the results browser to navigate to the noise analysis outputs - you can plot the contribution of any noise source (at the output) for any device in the circuit.
