Feb 11th, 2026, 11:06pm
How to save simulation results in AdvanceMS? (Read 3523 times)
delta
Finland
Jun 02nd, 2006, 12:31am
Mentor AdvanceMS has textio support now, but seems still not complete. This code works in modelsim vhdl, but not in ADMS:
process (clk,data)
    file df: text open WRITE_MODE is "simdata.dat";
    variable dl : line;
    begin
	  if clk'event and clk='1' then
		write(dl,data);
		writeline(df,dl);
	  end if;
    end process;
It seems ADMS requires "file_close" to write the file.
Could anybody please tell me how to save simulation data to a file for analyze (in matlab)? The LIST seems not working in my WIN versrion.
Paul
Switzerland
Re: How to save simulation results in AdvanceMS?
Reply #1 - Jun 21st, 2006, 7:54am
the file will be closed (written to the disk) at the end of your simulation. The end of the analog simulation in ADMS is determined by the simulation duration specified in the .TRAN command in your command file (.cmd). I hope this answers your question.
Paul
