cowell
World
does anybody read "wide-band cmos Low-Noise amplifier exploiting thermal noise canceling", published in IEEE on Feb,2004 ? i'm so confused by his explanation in the paragraph of "noise canceling principle". where he said the noises result from Rs and In,tr(transistor's noise current) can be cancelled while the noise of R cannot. i can understand to a extent that the In,tr can be cancelled. But for the Rs, whose noise calculation is same totally to the signal calculation, that is to say, the noise yielded by Rs on the Node X and Node Y should have opposite sign. This conclusion is different for the author. Besides, i cannot understand clearly why the Noise of R cannot be cancelled. I will appreciat it if anybody could patiently give me some hints about this. thanks in advance.
