Sep 24th, 2026, 11:23am
clock in the SC-CMFB of the opamp in pipelineADC (Read 4180 times)
baohulu
china
Jun 14th, 2006, 8:35am
hi,
in my design of pipeline ADC, I choose a common used SC-CMFB for my opamp, but I am not sure
whether the clock of the SC-CMFB of the opamp is the system clock of the pipeline ADC
for example, if my pipeline ADC is 100MSampling/s, then do I need to set my clock of the SC-CMFB of the opamp as 100MHz
Sid
Re: clock in the SC-CMFB of the opamp in pipelineA
Reply #1 - Jul 22nd, 2006, 8:23am
Sorry that you are getting a delayed answer for your question. The answer is typically YES. This is because the OTA does nothing during one half cycle and hence you can use fCMFB = fpipeline. For eg, when stage 1 samples the signal the OTA is not used and can hence be connected to the CMFB capacitors. During hold, the OTA is in amplify mode.
However, if your pipe is using OTA sharing between stages, this may or may not be possible and you may have to be more careful.
Hope this helps,
-Sid
vivkr
Reply #2 - Jul 31st, 2006, 4:56am
Sid wrote on Jul 22nd, 2006, 8:23am:
Hope this helps,
-Sid
Hi Sid,
This sounds dangerous to me. If I understand correctly, you are suggesting that the CMFB loop be broken during the amplification phase. That would not help much as this is the time when the CMFB should really be doing the job of controlling the CM levels. Improper or missing CM control can be fatal to circuit operation and performance.
Perhaps you mean something else.
Vivek
Reply #3 - Aug 1st, 2006, 6:02pm
Hi, all,
The clock of SC-CMFB is always non-overlapping clock, the same as the non-overlapping clock for sample and hold.  However, it doesn't matter that the CMFB cap should be tied to the opamp output at sampling phase or hold phase. In a pipelined ADC with amplifier sharing, the CMFB cap is tied to the opamp output at stage1's sampling phase and stage2's hold phase, or vice versa. So don't worry about it.
BG
Yawei
