Aug 18th, 2024, 5:19am
voltage gain and S21 relationship (Read 179 times)
cybq
Jun 15th, 2006, 5:01am
How to caculate the volatge gain of a two port network, knowing S21, S11, S22?
I made a simple passive network in ADS and run the S paraamters and transient simualtion,
and found S21 is less more than the voltage gain caculated using transient voltage when
S11/S22 are not matched.
What is those relationship between them? Any answer are welcome.
cybq
milkdragon
RF idiot
Re: voltage gain and S21 relationship
Reply #1 - Jun 15th, 2006, 9:39am
Voltage gain (let's call it Vg) = 20log(Vout/Vin) dB
Power Gain (S21,let's call it Pg) = 10log(Pout/Pin) = 10log[(Vout^2/Rout)/(Vin^2/Rin)]=10log[{(Vout/Vin)^2} * (Rin/Rout)]=20log(Vout/Vin)+10log(Rin/Rout) dB
So you will see that if the input and output impedance are the same, Pg is essentially equal to Vg.
However, if Rin <> Rout, you will see the difference between voltage gain and power gain
View Profile milkdragon   IP Logged
cheelee
Reply #2 - Jun 15th, 2006, 6:39pm
Have a look at this paper:
George D. Vendelin, Jose Carlos Pedro and Pedro Miguel Cabral, "Amplifier and Transistor Gain Revisited", Microwave Journal, Apr 2005
It has the equations relating 2-port S-parameters to voltage, current and power gain. Hope it helps.
cybq
Reply #3 - Jun 15th, 2006, 9:13pm
Thanks cheelee.
I want to say that S parameter is defined with voltage, for example, S21=b2/a1|a2=0, instead of power gain.
I'll search the paper you recommended.
cybq
