Aug 19th, 2024, 1:17am
choice of the clock of the SC-CMFB (Read 2193 times)
baohulu
china
Jun 15th, 2006, 9:35pm
HI,
if I design a 100MS/s pipelined ADC, and I use a opamp with a SC-CMFB, should I choose the clock of the SC-CMFB as 100MHz?
if it is sure. because the common used 6_switched_4_capacitors SC-CMFB can be equavilent as a switched resistor, with a value having the order of 1/(fclk*C), so if the fclk=100MHz, if I want to get a high switched resistance, say 100K, I have to choose the capactior value as 1/(100M*100K)=100fF, and this resistance is paralleled with the output resistance of opamp. so if I want to get a high gain, I need high output resistance , thus high the switched resistance, thus a much smaller capacitor in the SC-CMFB, right? but if the capacitor of the SC-CMFB goes too small, can it kick the disturbance of the paracitic capacitors?
regards
Re: choice of the clock of the SC-CMFB
Reply #1 - Jun 20th, 2006, 8:33am
Hi, Baohulu,
Sure you can select a smaller capacitor in SC-CMFM.  However, I don't understand what you said the disturbance of the parasitic capacitor.
Yawei
