jhuang
![](https://designers-guide.org/forum/avatars/blank.gif)
Analog/Power
Boston Area, USA
From the device physics, the resistance is inversely proportional to both mobility and carrier concentration. The mobility has a negative TC while the carrier concentration has a positive TC. So it all depends on which is dominant or more specifically the sheet resistance. I actually used such a process with NTC from p-poly and PTC from n-poly.
