Aug 22nd, 2024, 6:14am
resistor TC (Read 99 times)
microe
resistor TC
Jun 18th, 2006, 1:02am
I see in some process documents that N+ poly resistor has a negative Temperature coefficient while P+ poly resistor has a positive TC. What is the physical reason of that? Is it possible to have N+ poly with positive TC or P+ poly with negative TC?
Thanks.
jhuang
Analog/Power
Boston Area, USA
Re: resistor TC
Reply #1 - Jul 28th, 2006, 1:45pm
From the device physics, the resistance is inversely proportional to both mobility and carrier concentration. The mobility has a negative TC while the carrier concentration has a positive TC. So it all depends on which is dominant or more specifically the sheet resistance. I actually used such a process with NTC from p-poly and PTC from n-poly.
