Jul 18th, 2024, 7:29am
Output in ASCII format (Read 3567 times)
aamar
Jun 19th, 2006, 5:47am
Dear All,
I am trying to extract the simulation outputs in ascii format, in the spectre documentation it is stated that I can use the -format psfascii option, but where can I set this option in the GUI of the Virtuoso?
aamar
Re: Output in ASCII format
Reply #1 - Jul 24th, 2006, 2:00pm
There is no GUI setting to control the output format. This is because the tools need to be able to read the results...
You can probably specify "-f psfascii" in the userCmdLineOption field in the Setup->Environment form (I've not checked whether this works - it may not). You may also be able to specify the .cdsenv setting:
spectre.envOpts simOutputFormat string "psfascii"
but again, I've not checked that.
