Hi.
ADS have many sources and methods to generate random data.
For example, use "VtLFSR_DT" component if you use only ADS simulator since it can't be available in Spectre.
Also you can use custom Verilog-A code to generate random sequence. You can see examples in ahdlLib in cadence software distribution.
