Jul 22nd, 2024, 12:32am
is there any random function in RFDE or Cadence? (Read 2207 times)
cowell
World
Jun 19th, 2006, 7:51pm
i need to use a random function to generate a data randomly in RFDE (Cadence less),
and then use the data simultaneously in the simulation.
but i couldn`t find the function even after search the pdf files in RFDE.
any good hint will be appreciated.
regards
View Profile cowell   IP Logged
Re: is there any random function in RFDE or Cadenc
Reply #1 - Jun 22nd, 2006, 9:26am
Hi.
ADS have many sources and methods to generate random data.
For example, use "VtLFSR_DT" component if you use only ADS simulator
since it can't be available in Spectre.
Also you can use custom Verilog-A code to generate random sequence.
You can see examples in ahdlLib in cadence software distribution.
