Jul 20th, 2024, 11:30am
voltage controlled current source (Read 5534 times)
nandy
Timbuktu
Jun 21st, 2006, 3:05am
hi
I intend to design a ring VCO as shown in the figure. Could anyone suggest a voltage controlled current source that i could use to generate the control current (Ictrl)?
analog_wiz
Universe
Re: voltage controlled current source
Reply #1 - Jun 21st, 2006, 10:40pm
Hi , for desiggning a VCO u need to change the bias current of each of the inverters, i.e u need to vary the charging /discharging time.U can do this by changing the Vgs of an input transistor and then mirroring this to the inverter chains.Refer baker and boyce.
amarnath
nandy
Timbuktu
Reply #2 - Jun 22nd, 2006, 12:01am
yes in this case i am varying the charging/discharging time by varying the current. the trouble is if i yank the vgs of a mos and mirror the current, the current varies by a huge amount for a very small voltage range (about 0.1V only) and then the mos goes to triode. So i get an unreasonable large voltage-to-current gain for an unreasonably small input voltage range. what im looking for is a VCCS with a moderate gain over a large range of voltage (say 1V).
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #3 - Jun 27th, 2006, 6:21am
So, try to use a sum of constant current and voltage controlled current. Transistors should have very large L.
Make sure, the VCO runs at lower frequency vs. PVT when VC=VDD (Your work point is in the middle of the VC range and you have enough margin for post-layout)
If you don't have time to do it good
you will find time to do it again
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #4 - Jun 27th, 2006, 6:22am
And what you have to see
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #5 - Jun 30th, 2006, 1:09am
Dear nandu,
you asked the question. Did you see the answer?
kayathi
Reply #6 - Jul 10th, 2006, 3:27pm
Just a thought, did you try source degeneration on your transistor? - I guess it would help reducing the change of current with change in vgs.
-kayathi
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #7 - Jul 11th, 2006, 2:57am
No, I didn't use it. And even didn't think about it...
