mikki33
![](https://designers-guide.org/forum/avatars/blank.gif)
Analog/Mixed Signal/High Speed
Israel
So, try to use a sum of constant current and voltage controlled current. Transistors should have very large L. Make sure, the VCO runs at lower frequency vs. PVT when VC=VDD (Your work point is in the middle of the VC range and you have enough margin for post-layout)
