Peterraus
Lund University
When building an antenna in VerilogA, the simulation work for tran, ac and sp, but for pss, spectre indicates a hidden state of the variables L and C.
The antenna has an available power (receiving a signal at a certain frequency) and an impedance. The impedance is determined by the magnitude and angle of the reflection coefficient. In this way, a constant magnitude and swept angle represents all impedances that a circle with constant radius passes through in the smith chart. (A circle in the Smith chart corresponds to a constant VSWR value).
With this construction of the antenna, depending on the value of the angle, the impedance should be represented by a capacitor (lower part of Smith cart) or an inductor (upper part of Smith chart) in series with a resistor and a voltage source. I have put the inductor and capacitor in parallel and the angle determines which is conducting.
I have tried to "activate" the L and C for every timestep but, perhaps, since the angle is independent of the time it has not been a success.
Any ideas how to solve or completely eliminate the hidden state problem?
// VerilogA for DVBUnitcells, Antenna, veriloga
`include "constants.vams" `include "disciplines.vams"
module Antenna(v_ref, feed);
inout v_ref, feed;
/////////////////////// // v_ref is ground. // between ground and v is a voltage source v_source // between v and res is a resistor with value R // Between the resistor and the antenna feed is a capacitor or a inductor. //////////////////////
electrical v_ref, v, res, feed;
parameter real AvailablePower_dBm = -50 from (-inf:inf); parameter real Magnitude = 1m from [0:1); parameter real Angle_rad= 1m from [0:6.2832]; parameter real Frequency = 1G from (0:inf);
//local variables real AP, mag, ang, f, v_source, R, L, C, pi ;
analog begin
pi=3.14159265358979323846264338327950288419716939937511;
AP = AvailablePower_dBm; mag = Magnitude; ang = Angle_rad; f = Frequency;
if (mag == 0) begin mag = 1n; end
if (ang == 0) begin ang = 1n; end
if (ang>6.2831) begin ang = 6.2831; end
if (ang>3.1415 && ang<3.1416) begin ang = 3.1415; end
// x^y is in Skill x**y but in VerilogA pow(x,y).
v_source = sqrt(1E-3*pow(10,(AP/10)) *8*(-50*(-1+pow((mag*sin(ang)),2)+pow((mag*cos(ang)),2))/ (1+pow((mag*sin(ang)),2)-2*mag*cos(ang)+pow((mag*cos(ang)),2))));
R = -50*(-1+pow((mag*sin(ang)),2)+pow((mag*cos(ang)),2))/ (1+pow((mag*sin(ang)),2)-2*mag*cos(ang)+pow((mag*cos(ang)),2));
// Inductor and capacitor is parallel // but given values in a way that only one is conducting current
if (ang<=3.1415) begin // Inductor L =100*mag*sin(ang)/((1+pow((mag*sin(ang)),2)-2*mag*cos(ang)+ pow((mag*cos(ang)),2))*2*pi*f); C = 1a; //small but nonzero end
if (ang>=3.1416) begin //Capacitor C = 1/(2*pi*f*(-100*mag*sin(ang)/ (1+pow((mag*sin(ang)),2)-2*mag*cos(ang)+pow((mag*cos(ang)),2)))); L = 1; //Large end
V(v,v_ref) <+ v_source*sin(2*pi*Frequency*$abstime); V(v,v_ref) <+ ac_stim("ac",v_source); // ac only V(v,v_ref) <+ ac_stim("pss",v_source); // pss only V(v,v_ref) <+ ac_stim("sp",v_source); // sp only I(v,res) <+ V(v,res)/R; I(res,feed) <+ idt(V(res,feed)/L); I(res,feed) <+ ddt(V(res,feed)*C);
end //analog end endmodule
Peter Sjöblom peter.sjoblom@es.lth.se
