Jul 16th, 2024, 10:06am
Compact Modeling extension (Read 122 times)
A_Programmer
Jun 19th, 2006, 6:43pm
I am using HSPICE Y-2006.03. Does it support the compact modeling extension? If not, is there any way I can output variables like gm, gd, and etc? Thanks a lot.
Re: Compact Modeling extension
Reply #1 - Jun 20th, 2006, 7:42am
I believe the compiler supports it, but I forget the syntax for accessing (plotting) the values from within the simulator.
You could probably output the values with $strobe, of course, you'll want to be sure that ddx() works if you want gm.
A_Programmer
Reply #2 - Jun 22nd, 2006, 1:39am
Since some of my analog functions take many input parameters (like 20), is there a way to implement some of them as "global variables" instead of passing 20 input variables to a function?  Thanks a lot.
Reply #3 - Jun 22nd, 2006, 5:32am
A colleague at my company noticed that the "analog functions" in Verilog-AMS were strange beasts -- you have to declare them inside the module, but they don't have access to any of the other module-scope items, such as parameters.  So, I don't have a good suggestion for you.  I know some people use macros instead of functions because they find V-AMS functions lacking.
