Jul 19th, 2024, 7:31pm
gm boosting (Read 2609 times)
grosser
gm boosting
Jun 28th, 2006, 12:54am
hello
can you suggest me how to increase transconductance gmx of Mx transistor without increasing bias current?
what circuit solution i should use?
regards
aamar
Re: gm boosting
Reply #1 - Jun 29th, 2006, 6:20am
I think you should try to plot the gm vs. vds (at your (vgs-vth) bias value) for your transistor for different channel lengths while keeping the W/L ratio constant (so that the current will not be changed).
i.e. W=10*L and use the L as a parameteric sweep variable
I tried it and I think the larger the channel length (while W/L is constant) you can increase your gm.
Best regards,
aamar
Croaker
Re: gm boosting
Reply #2 - Jun 29th, 2006, 8:23am
Aamar, what is the reason for that?
These don't predict a higher gm under the conditions W/L=constant and I=constant.
gm=k*W/L*(Vgs-Vth)
gm=sqrt(2*I*k*W/L)
gm=2*I/(Vgs-Vth)
grosser
Re: gm boosting
Reply #3 - Jun 29th, 2006, 10:31am
Croaker is right
It's not so easy, but i really need a good solution, so if You have any ideas please public it here
regards
Croaker
Re: gm boosting
Reply #4 - Jun 29th, 2006, 11:35am
grosser wrote on Jun 29th, 2006, 10:31am:
Croaker is right
regards
I wasn't saying he wasn't right, only that I didn't get how that worked based on the simple square-law eqns.
vivkr
Re: gm boosting
Reply #5 - Jun 29th, 2006, 11:24pm
grosser wrote on Jun 28th, 2006, 12:54am:
hello
regards
You can certainly increase the Gm of Mx by using larger W/L ratio. Your bias current is set by the lower transistors and so this can be kept constant. In a differential pair, one can easily apply some small amount of +ve feedback to boost the Gm. You can look up the paper by Castello et al. (JSSC, June '90) and see if you can adapt his ideas somehow. However, be aware that circuits with +ve feedback need to be designed very carefully or else there will be instability. If nothing else works and you have access to good NPN BJTs, use them. MOS devices can never beat BJTs in terms of Gm/I. You will obviously need some way to compensate for the base current there.
The change in Gm vs. L is not apparent from the square-law model, and you cannot derive it thus. Short-channel devices have reduced Gm owing to velocity saturation which tends to shift the I-V curve from square-law towards a linear one. Look up any good device physics book (Tsividis for example).
Vivek
grosser
Re: gm boosting
Reply #6 - Jun 30th, 2006, 1:14am
vivkr wrote on Jun 29th, 2006, 11:24pm:
Vivek
Certainly larger W/L gives better transconductance, but i've already used the largerst possible W/L. Using longer channel and constant W/L increases gmx, but the increase is very small. I need about 5 times gmx
regards
mikki33
Analog/Mixed
Signal/High Speed
Israel
Re: gm boosting
Reply #7 - Jun 30th, 2006, 1:20am
You can make a replica of Mx and drive with that Nmos transistors at the output (25 pF), instead of cascoded current source. In this case you will have class A/B output stage with higher gain (and probably with lower current consumption)...
If you don't have time to do it good
you will find time to do it again
aamar
Re: gm boosting
Reply #8 - Jun 30th, 2006, 1:25am
Hello Croaker,
As Vivkr mentioned it cannot be derived from the square law model, or may be we cannot at the moment and it needs a look in a physics book, but from the practical point of view, I use the L to optimize the gm/gds of a transistor and in the same way I tried it only for the gm and the results were true, this means that gm can be improved with increasing the L till a limit where the change will not be noticable.
So I am sorry for not giving a clear answer now, but I will try to find it.
Best regards,
aamar
mikki33
Analog/Mixed
Signal/High Speed
Israel
Re: gm boosting
Reply #9 - Jun 30th, 2006, 2:04am
see the pic
grosser
Re: gm boosting
Reply #10 - Jun 30th, 2006, 2:26am
thank you for the pict
you mean it's a fully diferential opamp to the left?
i have found this soulution in attached picture but it doesn't work. it happens cause vdd=1.3V and vout to the left is 0.8V. this implies very low voltages at the opamps inputs which are cut-off
mikki33
Analog/Mixed
Signal/High Speed
Israel
Re: gm boosting
Reply #11 - Jun 30th, 2006, 3:00am
So, don't use sourse follower at the input. You may make OTA to be differential to differential instaed of differential to single ended and convert to singlr ended only at the output.
grosser
Re: gm boosting
Reply #12 - Jun 30th, 2006, 3:37am
mikki33 wrote on Jun 30th, 2006, 3:00am:
if i don't use source follower, i have 0.8V at the non inverting input and about 160mV at the inverting one. One input transistor is cutt-off and introduces low frequency parasitic poles.
