Aug 21st, 2024, 4:23pm
Pseudo differential amplifiers (Read 98 times)
mohanps
Jul 04th, 2006, 8:22pm
Are pseudo differential amplifiers supposed to burn lesser power
compared to fully differential ones with similar requirements
for slew rate, output swing and BW? Are there any good references
discussing actual implementation of pseudo differential amplifiers
Mohan
Sid
Re: Pseudo differential amplifiers
Reply #1 - Jul 15th, 2006, 6:15pm
A psedo differential amp basically does not have a bottom current source. Is this correct?
If I am correct, then it should not really affect your gain-BW-power trade-off. It will affect only your output swing and CMRR. If you have some kind of fast settling CMFB (common-mode feedback), then I think you can have "reasonable" CMRR and get away without problems in your pseudo differential amplifier.
Hope this helps.
-Sid
