Aug 23rd, 2024, 5:21am
about constant current reference (Read 1654 times)
caosl_zju
Jul 06th, 2006, 2:50am
hi,all
I need a constant current reference in my circuit, it's value is about 1uA.I summed a PTAT current from bandgap and a CTAT current to achieve this target, it's TC performance is ok, but the resistance's value will departure 20%, so the current value will change at different corners.Anyone has an idea to design a current reference which only relevant to resisitance's ratio more than it's absolute value.Any advice is welcome,thanks!
Jerome
Toulouse, France
Re: about constant current reference
Reply #1 - Jul 6th, 2006, 5:41am
To my knowledge, such a block does not exist (without trimming of course).
I remember searching for such a block through the IEEE litterature without
success. This was 4-5 years ago.
If you find one, I am interested.
Good luck, Jerome.
vivkr
Reply #2 - Jul 6th, 2006, 7:35am
There is no fundamental current reference. So you will have to live with the variation, unless you can use an external R, or if you can trim out the process variation of the on-chip R. Both techniques will require use of extra pins.
Vivek
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #3 - Jul 6th, 2006, 12:44pm
The use of external resistor is a common practice. In some cases it requires only 1 pin (if your groungs inside the chip and out are practically the same). In this case you may use 1% accuracy external resistor and get 3-5% accuracy of the "constant" current.
If you don't have time to do it good
you will find time to do it again
ycj
Hsin Chu, Taiwan
Reply #4 - Jul 11th, 2006, 8:46pm
Several papers have targeted this issue.
1. Stephen Tang, Siva Narendra, Vivek De from Intel proposed a method for sub-1V operation and file a patent on it.
2. S. Sengupta, K. Saurabh, and P.E. Allen ( Yes, that P.E. Allen of GATech ) proposed another method on ISCAS 2004.
I myself tried Sengupta's method and got good result (+/-9%) in simulation, but failed in Stephen's method.
Reply #5 - Aug 1st, 2006, 7:54pm
To quote the cited article:
"Measurements on a prototype chip, implemented in a 150nm logic process technology, validate the theories for two sub-1V MOS reference current generator circuits and show that 2X reduction in current variation is achievable across extremes of both process and temperature"
Not too terribly impressive. 2X of what? 40% down to 20% or?
To the best of what I know, the other opinions stated prior are accurate. Accurate voltage, not a problem. Accurate current requires a trim method or an external reference resistance. If anyone knows of something else, I would be very interested.
Jerry
ycj
Hsin Chu, Taiwan
Reply #6 - Aug 7th, 2006, 11:09pm
loose-electron wrote on Aug 1st, 2006, 7:54pm:
Jerry
So you can try Sengupta's method if you don't like Stephen's.
It is true that accurate current source is difficult to be implemented without trim or external reference resistance. However, good current source still can be achieved with some circuit skills.
ycj
Reply #7 - Aug 15th, 2006, 10:45pm
Hi guys,
Sometimes I wonder if we should seek constant current or not. For eg., a constant GBW and phase margin must be the final goal for designing the amplifier. However, GBW and phase margin vary as the PVT even if there is constant current reference.
If we try to stabilize GBW and phase margin as PVT vary, should we use a constant gm current source? But a constant gm current reference is inversely proportional to R. R varies with PVT. It's near 40% including 100 degree Celsius temperature variation and +/-20% resistance value variation due to process.
Any comments are appreciated.
Best regards,
Yawei
caosl_zju
Reply #8 - Sep 4th, 2006, 7:02pm
hi,ywguo,
   There are some other situations need constant current,for instance,in oscillator,i need a current to charge the capacitor.If this current is not constant well,the frequency will be vary too much that cannot be accepted.
