Aug 22nd, 2024, 4:17pm
sense resistance change (Read 2948 times)
avlsi
singapore
Jul 08th, 2006, 9:01am
hi,
I would like to know the various methods to sense resistance change between 1 Mega Ogm to 30 Mega Ohm. It should be able to sense a change of 1% or below.
Please tell me how to find things on this.
Thanks in advance
Winners never Quit,Quitters never Win
schmitt
Re: sense resistance change
Reply #1 - Jul 20th, 2006, 2:51am
Probably you can pump a known current and sense the voltage drop across the resistance. There can be some feedback loop which generates an error voltage by comparing the voltage drop with a fixed reference. This error voltage in turn could be used to minimize resistance variation.
matthewliao
China
Reply #2 - Jul 21st, 2006, 3:26am
or you can use a sample resistance in series of your resistance ; to ensure the accuracy, you can measure both
the votages of the sample resistance and your resistance.
Reply #3 - Aug 1st, 2006, 7:36pm
1 Meg to 30 Meg...
Yikes!
I do not know what you are trying to do, but if that is a resistance on a PCB, it is going to be sensitive to dust and humidity. It won't pass the "damp finger test"  ;D for a robust board design.
If that is a resistance inside a chip, unless it is a specialized process, it will get swamped due to leakage to bulk effects.
What are you trying to do here?
thanks,
Jerry
