![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
1 Meg to 30 Meg...
Yikes!
I do not know what you are trying to do, but if that is a resistance on a PCB, it is going to be sensitive to dust and humidity. It won't pass the "damp finger test" ;D for a robust board design.
If that is a resistance inside a chip, unless it is a specialized process, it will get swamped due to leakage to bulk effects.
What are you trying to do here?
thanks, Jerry
