Jul 16th, 2024, 12:03pm
VPI (Read 7749 times)
rajdeep
UK
VPI
Jul 09th, 2006, 8:59am
Hello everybody,
Can i call a C/C++ program while simulating a verilog-AMS model in cadence tool using ncsim?
The idea is to pass some of the signal values, obtained from simulation to an external C program.
The passng should be on the fly, i.e. the signal values should be continuously passed to the external program.
Rajdeep
A_Programmer
Re: VPI
Reply #1 - Jul 9th, 2006, 11:23pm
What is the advantage of doing this? Gain in simulation speed?
rajdeep
UK
Re: VPI
Reply #2 - Jul 10th, 2006, 2:46am
No, i've to do some calculations with the simulated signal values.. This  cannot be done online using ncsim. So, i need to take this data out and feed it to an  external program!!
But i.m still not sure, whether it is possible or not?
rajdeep
UK
Re: VPI
Reply #3 - Jul 16th, 2006, 7:55am
it will be nice to get an answer yes or no to this problem. This will help me greatly.
Rajdeep
Re: VPI
Reply #4 - Jul 17th, 2006, 4:44am
I guess no one on this forum has tried that.  Have you looked in the documentation or contacted your AE?
I wouldn't have said that ncsim can do Verilog-AMS; I thought Cadence's AMS product was AMS Designer.  I've personally never used VPI.
rajdeep
UK
Re: VPI
Reply #5 - Jul 18th, 2006, 12:58am
Thnaks a lot for the reply.  It need not to be ncsim. I want a cadence verilog-AMS simulator to have this feature VPI. According to the manual it has this feature, but with this can I call an external program written in C/C++ ??
Re: VPI
Reply #6 - Jul 24th, 2006, 2:09pm
AMS Designer is run using ncsim (with some special options). And yes it does support VPI. And yes you could interface to a C/C++ program. Or you could use SystemC?
rajdeep
UK
Re: VPI
Reply #7 - Jul 25th, 2006, 3:10am
Thank you very much!! I was going through the VPI chapters of the Verilog-AMS LRM. It isn't very easy to go through in one go...but thanx again for the reply
rajdeep
UK
Re: VPI
Reply #8 - Jul 25th, 2006, 3:25am
Can anybody help me to find a tutorial sort of thing on VPI?
Or, may be a pice of code/command liens that shows how to call an external C program!!
Thanks!
Re: VPI
Reply #9 - Jul 26th, 2006, 1:53pm
Raideep,
I don't have any VPI code for AMS handy, but I do have a very simple example that I wrote 8 years ago (an inverter) modeled in C - just to show the principle.
Because the code was a little too long to paste here directly, I converted it to pdf, and am attaching that.
rajdeep
UK
Re: VPI
Reply #10 - Jul 27th, 2006, 2:46pm
Thanks a lot Andrew!! The code looks very complicated with lots of inbuilt functions and datatypes. But this surely will give me a working example, and help me to understand how the different functions are used to make the callbacks.
I'll probably ask more and better questions once I understand this VPI stuff a little better.
Thanks a again. You have been a life saviour  :D
