Anders Jakobsson
Kista, Sweden
Hello folks! Im trying to implement an square root raised cosine FIR pulse shaping filter in verilogA. I have made two versions of this filter, one with coefficients from matlab and one that calculates its own coefficients. Both impulse responses are practically identical. I have also verified the coefficients in matlab by filtering two random I- and Q-signals. They constellation diagram looks like it should, with distinct constellation points only after applying the filter twice, however...
When I use the same coefficients in my verilog model it behaves allmost exactly like a normal raised cosine filter. It's as if the simulator runs the signal twice through the filter. I have tried using my own filter function and the built in numerator/denominator z-transform. Both produce the same result. The input data has been verified and I have tried different settings to no avail.
My questions are as follows, has anyone encountered a problem like this before? Would some kind spirit like to look at my code and try to find the problem?
Many many thanks in advance //Anders Jakobsson
Here is the code: //***************************************************************************** // ___ ___ ___ ___ // / __| _ \ _ \/ __| // \__ \ / / (__ // |___/_|_\_|_\\___| // //***************************************************************************** // FUNCTION: Square root raised cosine filter // VERSION: 1.0 // AUTHORS: Anders Jakobsson // // Description: // A square root raised cosine implementation // // PARAMETERS: // Period = Symbol period for which the filter is used. [s] // default 1u, range [0:inf) // // Gain = Gain of filter. [N/A] // default 1, range (-inf:inf) // // Delay = Initial delay of filter. [s] // default 0, range [0:inf] // //*****************************************************************************
`include "constants.h" `include "discipline.h"
//== Module definition == module SRRC2(in,out); input in; output out; voltage in,out;
//== Parameters == parameter real Period=1u from [0:inf); parameter real Gain=1 from (-inf:inf); parameter real Delay=0 from [0:inf]; parameter real Rolloff=0.5 from (0:1]; parameter integer Oversample=8 from [1:256]; parameter integer Groupdelay=4 from [1:256];
//== Variables == real T,G,P,OSR,R; real tnorm,n1,n2,d,squaresum; real taps[1:2*Groupdelay*Oversample+1]; integer midpoint,undef,i;
//== Analog section == analog begin @(initial_step) begin
//Clear variables undef=inf; squaresum=0; G=Groupdelay; P=Period; OSR=Oversample; R=Rolloff;
//Set sample period T=Period/OSR;
//Define coefficients //Calculate array midpoint index midpoint=G*OSR+1;
//set midpiont coefficient ( to h(1) ) tnorm=1/OSR; //Calc. tnorm=t/P n1=4*R*cos((1+R)*`M_PI*tnorm); //Calc. term one of numerator n2=(1/tnorm)*sin((1-R)*`M_PI*tnorm); //Calc. term two of numerator d=`M_PI*(1-pow((4*R*tnorm),2))*sqrt(T); //Calc. denominator taps[midpoint]=(n1+n2)/d; //Calc. midle impulse response
//set other coefficients. only half calculated and mirrored to other half for(i=1;i<=midpoint-1;i=i+1) begin tnorm=(i+1)/OSR; //Calc. tnorm=t/P n1=4*R*cos((1+R)*`M_PI*tnorm); //Calc. term one of numerator n2=(1/tnorm)*sin((1-R)*`M_PI*tnorm); //Calc. term two of numerator d=`M_PI*(1-pow((4*R*tnorm),2))*sqrt(T); //Calc. denominator //Check for zero denominator if(d!=0) begin taps[midpoint+i]=(n1+n2)/d; //Set point and "mirror point" taps[midpoint-i]=taps[midpoint+i]; end else undef=i; end
if(undef!=inf) begin //If the denominator is zero, the value i=midpoint+undef; //is interpolated from the adjacent values taps[i]=( taps[i-1]+taps[i+1] )/2; i=midpoint-undef; taps[i]=( taps[i-1]+taps[i+1] )/2; end
//Scale coefficients to some decent value for(i=1;i<=2*G*OSR+1;i=i+1) squaresum=squaresum+pow(taps[i],2); squaresum=5*sqrt(squaresum); for(i=1;i<=2*G*OSR+1;i=i+1) taps[i]=taps[i]/squaresum;
//Filters the input signal V(out) <+ Gain*zi_nd(V(in), taps, {1}, T,T,Delay); end endmodule
