Aug 18th, 2024, 6:19am
Filter Gain Response (Read 674 times)
Visjnoe
Jul 12th, 2006, 8:47am
I'm in the process of designing a Chebyshev bandpass filter (gm-C) with a passband ripple of 0.1dB.
It's however very difficult to come with the device sizes that make sure that the (typical) transistor-level simulation
has the same gain response as e.g. the MATLAB toolbox generated filter gain response. To this end, I'm now resorting to optimisation  :)
Anyway, I was just considering that - in general- it's very important to be on that curve? Or is close enough good enough?  :)
Kind Regards
Peter
vivkr
Re: Filter Gain Response
Reply #1 - Jul 13th, 2006, 12:39am
Hi Peter,
As long as the filter fulfils all requirements of your application, and is robust enough that
process variations and mismatch do not push it beyond spec, I see no reason to be absolutely
faithful to the ideal Chebyshev response.
As for how much is good enough, you need to decide that.
Vivek
ACWWong
Oxford, UK
Reply #2 - Jul 17th, 2006, 8:16am
I agree, so long as you can meet the system requirements (ie inband ripple & gain, groupdelay, signal handling, noise, out-of-band rejection, power, area etc.) then it'll be fine.
I have designed a few gmC filters for wireless transceivers in the past, and have always envitably had to tweak gm values and C values to "optimise" (mostly to correctly centre the response and "square up" the shoulders) when using real kit devices to get nearer the ideal mathematical response.
as you are using gmC, I guess you have some tuning mechanism to overcome PVT spread.
