Aug 23rd, 2024, 12:19am
High speed opamps (Read 2925 times)
venkatakalluru
Hyderabad, India
High speed opamps
Jul 13th, 2006, 10:35am
I am designing a highspeed opamp for a pipelined ADC application. The required UGB is anywhere between 800Meg to 1G. The design is on 0.35u process. I have chosen folded cascode with gain boosting technique for the amp (A fully differential opamp with SC-CMFB). To meet the high gain spec , I have no other option than to pump more and more current into the opamp. This made my transistors too big. Though the schematic is working fine, I encounter problems when I simulate C-extracted version. The parasitic caps due to huge transistors prove fatal to my phase margin and speed. Now my question is
1)Before proceeding into high speed design, are there any subtle points I need to take care of?
2) Is there anyway I can bypass these huge sizes of transistors?
Any reference or book on this issue will be highly useful.
kalluru
huh... analog design
TT
Re: High speed opamps
Reply #1 - Jul 14th, 2006, 6:05pm
What do you call a C-extracted version ? If you are talking about parasitic extraction after layout then
I think your design flow may have a bug. The simulated version should use a model which include at least
gate source capacitors. Then if after C extracted version you have a bug then either your interconnect
are too important (which I doubt compared to Cox density) either the parasitic extractor may not
get the correct values.
Usually at these UGB freq, you'd better use large Vgs if possible, even if from a gm/Id pt of view it is not the best
option. (be careful with 1/f noise) Try to use small current and small size first, because using large current requires
large W which gives large cap then need large current, etc ...
Reply #2 - Aug 4th, 2006, 8:28am
Do you really want an op-amp here?
The stated bandwidth was up to 1GHz. Typically I stop using feedback amplifiers above 100MHz or so (for 0.18 CMOS types of processes)
Consider some common source differential pair amplifiers, without feedback. and you will need to do some correction circutis for gain errors, watch your linearity, and things like that.
Faisal
Reply #3 - Aug 7th, 2006, 5:48am
Interesting problem, you have on your hands  ;D
What is the intended speed of your ADC.. or specifically your switched capacitor gain stage (settling phase in nsec) ??
