Aug 15th, 2024, 6:42am
Random behavior of $random() in SpectreHDL (Read 5490 times)
vivkr
Jul 17th, 2006, 12:04am
I wonder if the $random() function is recomputed each time a new analysis runs.
I have an AHDL block where I generate a random number in the "initial" section of
the code, and store it in a local variable, which is used in the "analog" section to
output a random voltage.
The DC output is different when seen by annotating or printing the DC operating point
of the circuit, as compared to the DC level seen in the transient analysis. There appears
to be no correlation between the quantities either.
Is this normal behavior? The core of the code is quite simply:
real x;
initial{
x=random();
analog{
V(out) <- vref*x;
Vivek
Re: Random behavior of $random() in SpectreHDL
Reply #1 - Jul 20th, 2006, 4:18am
The LRM says that, since you did not specify a seed, the simulator picks one, and I guess it picks a different one for each analysis.
If you want a consistent value, then you should specify a seed.
real x;
int seed;
initial begin
 seed = 123;
 x = random(seed);
analog
 V(out) <+ vref * x;
Reply #2 - Jul 24th, 2006, 1:42pm
Note, SpectreHDL is end-of-lifed - in fact it has gone in MMSIM61, the latest release of spectre. So don't use it... use Verilog-A. Geoffrey's answer was for Verilog-A.
There was a fix recently to do with repeatability of random numbers (I think all instances ended up with the same
sequence, when no seed was specified, and that was fixed) - but I can't remember precisely what it was...
Reply #3 - Jul 31st, 2006, 7:21am
Andrew Beckett wrote on Jul 24th, 2006, 1:42pm:
Oops, thanks Andrew.  I guess I didn't read the subject closely.
