Do you have the hspiceva license? The Verilog-A compiler only comes with some versions of HSpice; there is a "basic" version that does not have it.
Also ... you should be running hspice on a hspice-format netlist, with the proper command to include the Verilog-A file -- you can't run hspice on the verilog-a file itself.
