Jul 16th, 2024, 11:31am
How to run simulation of verilogA files? (Read 1034 times)
ADDA
Jul 19th, 2006, 5:22am
Can spectre do it?
How about hspice?
Thanks.
bernd
Munich/Germany
Re: How to run simulation of verilogA files?
Reply #1 - Jul 19th, 2006, 8:03am
Both simulators have the capability to simulate Verilog-A models,
Spectre definitely and for HSpice have a look at
http://www.synopsys.com/links/hspice_news_spring05.html
Sometimes it helps to have a look at EDA Vendors Product information
published on their Websites.
Bernd
Just another lonesome cad guy
Gino
Reply #2 - Sep 4th, 2006, 5:47pm
I have a problem about simulating the verilog-a model in HSPICE(2005.09-SP1).
I run the verilog-a demo file in HSPICE directory, and an error message displays
** error **During Verilog-A Device processing: CML file does not exist
It seems that I lack the complier model library. How do I solve this problem?
Do I need to install any other program?
Thanks.
Reply #3 - Sep 5th, 2006, 6:20am
Do you have the hspiceva license?  The Verilog-A compiler only comes with some versions of HSpice; there is a "basic" version that does not have it.
Also ... you should be running hspice on a hspice-format netlist, with the proper command to include the Verilog-A file -- you can't run hspice on the verilog-a file itself.
