vivkr
Hi Yawei,
I agree that normally it is not needed to perform such a conversion. However, if you are clocking at a very high rate, and latching the comparators well before the MDAC output is settled, then there is some scope for such errors, when taking the comparator offsets into account, at low supply levels.
Nonetheless, how would you select an appropriate Gray code assignment out of all the possible ones for say, a flash ADC.
Regards Vivek
