Jul 22nd, 2024, 12:25am
SpectreRF Settings for Figures in sc-filters.pdf (Read 4739 times)
dwingram
Jul 19th, 2006, 2:37pm
I am trying to reproduce some of the figures found in the document, sc-netlists.pdf. Specifically the ones on pp. 14-15, figures 6-8. I have run through the simulations and it is clear that the setup for each simulation doesn't directly correspond to these figures. Even though I can come close, it would be very convenient to be able to reproduce them identically, within reason.
dwingram
Re: SpectreRF Settings for Figures in sc-filters.p
Reply #1 - Jul 20th, 2006, 9:37am
Have you tried downloading the netlists?
dwingram
Reply #2 - Jul 20th, 2006, 9:53am
Thanks for the reply.
I have downloaded the netlists and have run the simulations many times. The results I have obtained do not appear to directly map to the figures to which I referred in the document. I am confident that it is simply a misunderstanding on my part.
For example, Figure 8 illustrates the transfer functions from the input, for sidebands up to +/- 25, to the output at baseband. The graph shows transfer functions out to ~10MHz, but in the pss analysis statement, maxacfreq=6MHz. It is not clear to me how the pxf analysis can evaluate sidebands beyond maxacfreq.
dwingram
Reply #3 - Jul 20th, 2006, 11:46am
Ken,
I believe my problem with this analysis is that I have been simulation using the switched capacitor filter netlist and not the track and hold netlist. Thanks for replying earlier.
dwingram
dwingram
Reply #4 - Jul 20th, 2006, 2:27pm
Now that I have the right circuit running, I can reproduce Figures 6 and 7 from the document, but my attempt at Figure 8 is not quite what you display in the document.
I am running the tah.ckt netlist using spectre version 6.1.0.151.
dwingram
Reply #5 - Jul 28th, 2006, 4:53pm
There was an error in the paper. To get the results shown in Fig 8, the PXF analysis must use the node 'sout' rather than the node 'out'. I have updated the paper and the netlists.
dwingram
Reply #6 - Jul 31st, 2006, 9:13am
Ken,
Thanks again for the assistance, I have confirmed the simulation results match Figure 8.
dwingram
