there is a paper related a method decreasing the clock feedthrough effect, "A 1.5V 50MHz pseudodifferential CMOS sample and hold circuit with low hold pedestal" IEEE. transactions on circuits and systems-I:regular papers vol.52,No.9,Sep.2005. I have tried this method, but I don't get a better result, I don't know whether there is something wrong with my design. however, hope this can indicate you something. and if you have got a better performance, please tell me.
I also have a question to ask you, in your opa, does it use a SC-CMFB, if yes, what is the type of the switch in your SC-CMFB, I use also the bootstrap type, but the charge injection and clock feed through is big , and this type can't make the CMFB stable to a VCM. I don't know what is type is suitable for the SC-CMFB.
xaviar wrote on Jul 22nd, 2006, 6:45pm:My design requirement is SFDR>80dB.I had read some paper about it,most of them consider Vsb=/0 is the frist reason to distortion.My design implement not support triple-well technology,so choose pmos transistor is the only choice to me.Using pmos means more bigger W/L than the counterpart in order to achieve same Ron.
Firstly, large W/L have obvious feedthrough effect which is relate to Vin,it decrease the performance of switch.From the viewpoint of theory,bottom-plate sample can eliminate feedthrough and charge injection,but i use bottom-plate sample structure in Hspice, the result of simulation is that Vout is floating.How to configure the circuit to eliminate the feedthrough effect.
Futhermore, in order to compare the bulk-effect-free structure with bulk-effect structure,two structure is simulated by Hspice.The simulation indicate that bulk-effect-free structure decrease SFDR by 3dB,Why??
Last but no the least,what is the correct method to measure the performance of switch.I use Hspice to get *.tr0 and import the data to Matlab.It is found that TIME parameter is changing step,so it can't using period sampling.I have used a sine wave to test this method,some harmonic distortion (about - 60dB)and noise can be saw in the FFT plot-so confused! So mybe this method has fault,how to resolve it.
xaviar
