Jul 18th, 2024, 3:25am
About symbol draw (Read 6067 times)
taos
About symbol draw
Jul 26th, 2006, 4:34am
In the Cadence Symbol Editing, how to change the line from green to white?
bernd
Munich/Germany
Re: About symbol draw
Reply #1 - Jul 26th, 2006, 6:17am
The green lines in the Cadence Symbol Editor are drawn on the
system layer purpose pair (lpp) 'device drawing', which is assigned to
the display packet 'green' in the technology file.
If you want to change the color of them you have to assign a other
display packet to 'device drawing' lpp in your technology file.
But this changes the color appearance of every shape drawn with the
lpp 'device drawing' no mater if it is for symbols,
schematics or layouts.
No other way around this!
Have a look at:
http://sourcelink.cadence.com/docs/db/kdb/2004/Aug/11150798.html
For what reason do you need white lines?
Bernd
Just another lonesome cad guy
ACWWong
Oxford, UK
Reply #2 - Jul 26th, 2006, 6:18am
instead of Add->Shape you can use Add->Note->Shape (or shortcut n) to get white.
what's wrong with green anyway ? its looks rather nice.
taos
Reply #3 - Jul 28th, 2006, 4:33am
Thank you! I only wnat to draw a A4 pattern to describe the schematic.
bernd
Munich/Germany
Reply #4 - Jul 28th, 2006, 5:34am
If you want to have a sheet surrounding you schematic, there are sample
libraries in the Cadence DFII installation directory, have a look at
<install_dir>/tools/dfII/samples/cdslib/sheets
Bernd
