Aug 31st, 2024, 10:14pm
mismatch modeling in simulation (Read 2801 times)
dandelion
Aug 01st, 2006, 7:21pm
We hope to do some mismach analysis when design our cicruit. But, unfortuntely, there is no mismatch parameter for our spice model.So I jsut vary the width 10~20% for the matched transistor. I know there is also the mismatch for the transistor lenght and the threshold voltage etc..But I just vary the transistor width.
Is there any risks when doing mismatch analysis for it?
Re: mismatch modeling in simulation
Reply #1 - Aug 2nd, 2006, 4:52am
If you vary the width, then the mismatch in current will be approximately linear, because the current goes to first order as W/L*beta*f(Vgs, Vds).
If you are operating in the linear region, then I guess this might be OK, since a variation in threshold voltage will also be linear.  But then again, variation in length will cause an 1/x variation in current.  And, if you are in subthreshold, you're completely toast, because a threshold voltage mismatch will cause an exponential mismatch in current.
Reply #2 - Aug 15th, 2006, 9:16pm
What foundry process is this? and what channel length are you at?
The reason I ask - as you go under 90nm and the introduction of channles being shortened by "halo" methods and similar matching goes to garbage very quickly.
Consequently, playing with 20% channel geometry mismatch may not be enough.
Push back on the foundry really really hard for some matching data.
Jerry
