Aug 24th, 2024, 12:19am
A basic question? (Read 4639 times)
average
A basic question?
Aug 08th, 2006, 2:23am
  Does the mosfet have the channel_length modulation effect when it operates in the triode region?
        Green
jeffyan
Re: A basic question?
Reply #1 - Aug 8th, 2006, 2:47am
average wrote on Aug 8th, 2006, 2:23am:
        Green
hi,
as i know, the channel_length modulation effect is defined in mosfet's saturation region.
jeff.yan
Reply #2 - Aug 8th, 2006, 10:23am
Channel length modulation is applicible only in saturation region. You need to have a pinch off scenario in place, so that the pinch off location changes.
When you are in triode region the entire channel is inverted (drain to source fully) so length modulation is not applicable.
hope that helps
Jerry
ACWWong
Oxford, UK
Reply #3 - Aug 8th, 2006, 10:56am
loose-electron wrote on Aug 8th, 2006, 10:23am:
hope that helps
Jerry
When you are in triode region, the entire channel is indeed inverted, but you can still have pinch-off due to velocity satuation (short channel effect). Although this is not "channel length modulation" in the traditional sense, the velocity saturation point is dependant on Vds, so the effects are similar to channel length modulation (ie, you see the knee in the Ids vs vds graph within the triode region).
This effect only occurs (as the name depicts) on short channel devices/high field strength situations.
Reply #4 - Aug 8th, 2006, 11:18am
Well yes, agreed -
But there is a lot of bad information in textbooks on velocity saturation
Pinchoff Region – Electron carriers in the pinched-off region are velocity saturated,
Many texts use the illustration: "velocity saturation is similar to a gas under pressure traveling through a very small tube“
I still don't know who the originator of that one is. It is a nice illustration, but not valid.
Carrier velocity saturation is caused by horizontal electric fields to the channel. end.
For an in depth discussion see:
"Carrier Mobility and Current Saturation in the MOS transistor"
IEEE Transactions on Electron Devices, March 1965.
I wish I had an e-copy of the above, but it predates most computers.
- Jerry
average
Reply #5 - Aug 8th, 2006, 5:57pm
I think your replies are very helpful for me, thanks all.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #6 - Aug 21st, 2006, 1:46am
jeffyan wrote on Aug 8th, 2006, 2:47am:
        Green
hi,
jeff.yan
I agree with you, jeff.
