Sep 16th, 2026, 10:55pm
Measuring Jitter from an Eye-Diagram (Read 7822 times)
always@smart
ASIA
Aug 08th, 2006, 7:27pm
Dear All,
I have a query here.
Does anyone here know how to use the calculator or other way to get the jitter from an eye-diagram without DIY.
THank in advance.
smart
Smart
sugar
Re: Measuring Jitter from an Eye-Diagram
Reply #1 - Aug 9th, 2006, 9:44pm
use verilog-a
always@smart
ASIA
Reply #2 - Aug 10th, 2006, 7:40pm
Hi sugar,
Thank you for taking initiative to reply me.
Do you hav any example for it by using verilog-a?
regards,
smart
Smart
always@smart
ASIA
Reply #3 - Aug 14th, 2006, 1:12am
can anyone here please help me on this issue?
Smart
Smart
Reply #4 - Aug 14th, 2006, 9:09am
If you are using the Cadence software, you might want to look around in the libraries provided with Artist. I seem to remember there being a verilog-a model that was designed to produce eye-diagrams.
Jess Chen
California Bay Area
Reply #5 - Aug 14th, 2006, 9:37am
Look in rfLib. The catatory is "measurement". The element is called eye_diagram_generator. It is documented in the SpectreRF User's Guide. There is also a new function in the waveform calculator for creating eye-diagrams. The rfLib element does not compute jitter directly and I don' know if the waveform calculator does it. However, as "sugar" suggests, you should be able to compute jitter using VerilogA.  I would measure jitter with the zero-crossings. You can use the @cross statement to detect the zero crossing. You may get some ideas from the rfLib/comms_instr element for creating histograms and statistics from the zero-crossings using VerilgoA You will have to subtract off k*T from the zero crossing where T is the symbol period and k is the kth crossing. But you may be able to use a modulo function instead. You should be able to compute all the statistics on the fly, i.e. recursively, instead post-processing the data. Again, the comms_instr block may give you some ideas on how to do that. If you get it working, I am sure most of us would like to see your code posted to this forum.
Another option is to write the zero crossings to a file using VerilogA and then post-process with Matlab, Mathematica, or Excel.
always@smart
ASIA
Reply #6 - Aug 14th, 2006, 6:48pm
Dear Ken Kundert and Jess Chen,
Thank you for the guide.
Yes, I'm using Cadence. I'm not familiar with the verilogA, so i wonder if that is a way to use the Ocean built in function with some mathematical formula to obtain the jitter value?
or someone can help me in verilogA (to get the jitter)?
Please shed me more light  ;)
Smart
Smart
jbdavid
Reply #7 - Aug 30th, 2006, 10:12pm
I seem to recall a Jitter measurement block in bmslib as well
(search the forum for bmslib- its been discussed before..)
Jonathan
jbdavid
