Aug 23rd, 2024, 6:15am
HCE(hot carrier effect) risk for my deisgn (Read 1640 times)
dandelion
Aug 09th, 2006, 11:11pm
I am desiging a mixed signal block for which the output buffer is an inverter chains to drive the 1pF load capacitor. The design is based on the 0.5um CMOS.I use the minimum length for the inverter buffer with speed considerations.But I have some concern that the minimum length will bring the hot carrier effects which will affect the life of the product.
Pls. comment!
Re: HCE(hot carrier effect) risk for my deisgn
Reply #1 - Aug 10th, 2006, 11:36pm
What you are doing is done all over the place with many designs. It should not be a problem.
