sandyk
Hi evryone,
Giving you the complete details...
a Universal Amplifier block so that one can get all the basic amplifier functions , i.e., VCVS, VCCS,CCCS,CCVS from this single module.
0.5 micron CMOS process.
+ and – 3V power supplies (Maximum)
sample calculations regarding design and verify with simulation results (HSPICE, level=3)
Minimum gain should be 100 units (for VCCS the unit could be milli mho or micro mho)
a data sheet summarizing important parameters of the amplifier module. Some of these will be
* Total DC power consumption * Total transistor area used * Number of external voltage/current sources needed * Interconnection hints for obtaining a specific amplifier function (i.e., VCVS) * Gain at low frequency and band-width (-3dB) (show test set-up) * Input and output resistances (show the test set-up) * Overall output-input delay (1pf load) (show test set-up) * Overall settling time (1 pf load) (show test set-up) * Slew rate (open circuit, 1 pf load) (show test set-up) * Input common mode range (voltage or current) for linear operation (show test set-up)
schematics of all the sub-systems employed.
gain and phase plots
