Sep 18th, 2024, 12:52am
Why does phase noise change from + to - ? (Read 7586 times)
kappy
Aug 15th, 2006, 6:18pm
Dear Everyone!
I have a question about the phase noise simulation.
I think in case that VCO operates properly, phase noise at carrier
frequency should be 0 and negative as the offset frequency is increased.
But in case of my SpectreRF simulation results,  phase noise at 1Hz is 90dB
and the phase noise at 1.6kHz is 0dB and becomes negative over 1.6kHz offset.
I don't think this mean the carrier power and power at 1.6kHz offset
is the same.  In case of spectreRF phase noise simulation, why does
the SpectreRF phase noise change from + to - ? and what does 0dB
phase noise mean in the SpectreRF simulation?
By any chance, Does SpectreRF normalize phase noise with 1.6kHz offset
power? If then, how can I change normalization frequency?
« Last Edit: Aug 15th, 2006, 7:57pm by kappy »
Re: Why does phase noise change from + to - ?
Reply #1 - Aug 16th, 2006, 12:21am
Read section 30.0 in http://www.designers-guide.org/Theory/cyclo-preso.pdf. The basic idea is that in practice there is a low frequency corner that is caused by large signal effects and the simulators cannot predict because they are using small-signal analysis. Clearly the noise cannot be 90dB at 1Hz because that would imply that the total noise power in the normalized noise curve is much greater than one. There must be a corner, and the frequency must be such that the total area under the normalized noise L is 1.
Reply #2 - Aug 16th, 2006, 12:22am
By the way, if the answer I gave is not satisfactory, search around on this forum. This question has been asked and answered repeatedly.
David Lee
Reply #3 - Aug 16th, 2006, 8:43pm
Hi Kappy,
Phase noise spectrum, L(fm), is the power spectral density of the noisy oscillator waveform, measured around the fundamental, divided by the power of the noiseless oscillator waveform, at the fundamental. Adding noise to an oscillator does little to change the total signal power. So the area under the first power spectral density is the same as the area under the second power density, i.e. power conserves. Therefore, the area under the phase noise curve is always one. For typical oscillators, phase noise is below 0 dBc/Hz around the fundamental and away from the fundamental. For ultra-low-noise oscillators, phase noise is above 0 dBc/Hz at offsets less than 1 Hz. Measured phase noise can never be above 0 dBc/Hz at offsets larger than 1 Hz. If this were the case, the area under phase noise curve would exceed one. Carefully note that measured phase noise at carrier frequency is rarely 0 dBc/Hz.
David
« Last Edit: Aug 17th, 2006, 1:20am by David Lee »
- David
Frank Wiedmann
Munich, Germany
Reply #4 - Aug 17th, 2006, 12:05am
Ken Kundert wrote on Aug 16th, 2006, 12:22am:
See e.g. http://www.designers-guide.org/Forum/?board=rfsim;action=display;num=1050465395;....
kappy
Reply #5 - Aug 17th, 2006, 6:47am
Dear Ken Kundert, David Lee and Frank Wiedmann
Thank you very much for your kind answers.
I didn't know my question was repeated one.
I should check the previous answers like you said.
I think it will take some more time for me to understand clearly.
 Before that, just one more question.
I modified my VCO and I want to check if the modified VCO is
really more improved than previous one by simulating phase noise.
And these two VCO have different positive values at 1 Hz offset.
I measure the phase noise difference (A) of the previous VCO between 1Hz and 1kHz offset
and then I checked the phase noise difference (B) of the modified VCO between 1Hz and 1kHz offset.
If A < B, Does it mean that modified VCO is better than previous VCO considering phase
noise?  if this method is not correct, please, let me know the correct method.
kappy
Reply #6 - Oct 8th, 2006, 11:04pm
kappy wrote on Aug 17th, 2006, 6:47am:
