Apr 30th, 2024, 8:42pm
Pages: 1 2
ESD strategy in a multi-power domains chip (Read 21566 times)
Re: ESD strategy in a multi-power domains chip
Reply #15 - Nov 13th, 2006, 10:08am
ACW and SRF -
Good comments folks, I especially liked the concept of using the largest substrate ground as the common tie point.
One minor element to remeber on ESD - You need to have an ESD scenario that plugs and plays in both a packaged device, and a raw die (no package, no bond wires) as well.
Most, but not all, assembly houses have cleaned up their ESD problems in-house, but I ran into a chip a couple years back where the ESD was dependent on the interconnecto of the package, and a heap of chips were getting fried between wafer test and final package test.
Jerry
SRF Tech
Arizona
Reply #16 - Nov 13th, 2006, 2:32pm
Jerry,
The large common ground point has worked very well for me on many different products and technologies, but as ACW pointed out, layout and placement of the diodes and power bussing become critical with this approach.  In all honesty, to do it right, you should also address noise and power distribution at the same time.
With regard to your point about raw die, that is an excellent reminder.  I have seen more and more issues lately with problems related to this, and to a greater degree, in multi-chip packages where the ESD becomes dependent on the relationship between multiple die and their related interconnect in the same package.
regards,
SRF
www.srftechnologies.com
Pages: 1 2
